I've just installed a new Quad Core CPU in my machine. Now when I fire up the PC I get an error message straight up - uCode Loading Error Press
F1 to continue.
Once I press F1 everything then starts up fine ...... any ideas?
Update the bios on the mobo, it doesn't recognise the code the CPU gives it.
Silly question - is the mobo designed for a quad core cpu?
Originally posted by RazMan
Silly question - is the mobo designed for a quad core cpu?![]()
was it as cheap as buying from me ?
www.callright.co.uk
i also discount for locost builders, also next day delivery......
I'll check with you next time
BTW - the Bios update sorted it..... thanks chaps.
