As above really has anyone fitted the headights to the cycle wings for the "lit where you're going" effect or is it too flimsy/shaky to be worthwhile?
I would think the wings would be to unstable they have enough trouble supporting their own weight
Fair enough it would be brilliant if they could be fixed around there somehow though
problem is the wing stays not the wings you would also have to mount the wing higher to accomodate the wiring and headlight base mounting
taken from IVA Manual, section 20
Note 5: Lamp security - Lamps must be securely mounted to the vehicle, double-sided tape as a method of attachment is to be considered acceptable only in situations where it is the manufacturer's intended method
Note 6: Lamp position. Achieving position requirements by masking external parts of the illuminated area is not acceptable. However except for headlamps, internal masking or internal painting of lamp lenses is permitted but this must be permanent and must not affect lamp intensity.
Man, don't you guys have enough problems putting these wretched things together?? With small LEDs though, it shouldn't weigh much. But the stay would have to made of kryptonite or something because of all the bouncing around.
Well the bouncing around was the consideration
Switch to clam shell wings?, just a thought,.... I will go away again now then.
Adrian
You could always copy the Citroen DS - put a link between the steering mechanism and pivoting headlamps.
Then think about the amount of driving in darkness you'll be doing and work out whether it is worth the effort.
I was going to bolt a head lamp to the top of my crash helmet for the ''light what you see'' approach---------- just an idea
Problem with mounting them to the wings (cycle type) is that the first time you are opposite locking it at night down a dark country lane the
headlights will be pointing one way whilst you are going the other (I kid you not!).
Cheers, Pewe
On my rally escort we would point a set of spots so that the right hand side pointed left and the left hand side pointed right to give maximum
advantage around corners, works fine on opposite lock too
RD
I was thinking about fitting some small drivin lights to the tops of my wing for the same effect but leaving the headlights fixed
Jap import mk2 MR2's have driving lights that move with the steering angle, in addition to the normal headlamps. They look quite small from the outside, I have no idea how big the mechanism hiding behind the bumper is though.
