heres a little write up on what i have found when i come to paint a car.after asking on here and looking around the net i didnt find much help, so i
just bought the stuff and got on with it :d
heres what i got
2l gloss black Synthetic £12 per L
1l Synthetic thinner £5.00
5l standard thinner £6.50 to clean gun
paint gun £32
this is what i have found, there is no quick way to do this and get a good finish.
compressor
i only have a 25l compressor and its a pile of cak but for now it will have to do. i set the pressure to 60 psi, you need a filter to stop the water
as i have found out. so if you are about to start without one (dont) you will make more work for yourself then its worth. but i did put the pipe over
a beam in the unit to try and stop the water running up the pipe this did work.
spray gun
turn all the knobs to zero thats all the way in, the knob on the top is the paint flow turn 2 turns out and try from there. the knob on the side is
for the fan of the paint, turn this just a bit to start with and test on a bit of paper or wall lol. i had the fan about 4in holding the gun about
10in away .
prep
start by sanding down with 800 grit paper on some of the panels i have just used scotch bright. the longer you spend preping the better the finish.
before you spray make sure there are (no) bits on the panel, make sure there are no bits on the panels. make sure there are no bits of crap on the
panels lol. wipe the panel with the (Synthetic) thinners then run your hand over the panel and i bet you still have bits.you have to take your time
wiping down.
paint
right this paint i like treacle its really thick but you only need 10% thinners,you dont need a top coat of clear with this paint, i started off
thick and thinned it down to suit, when i started adding the thinner the paint just started going from a thick guuu to a bit like water. adding a bit
more thinners at a time. but you dont need this paint to be like water too spray it.
for the first coat just (dust) dont try to be a smart arse and try and do it in one. not that i did
then (wait) 20 mins inbetween coats.
i done 4 coats to get a nice finish.
i will be cutting the paint back after its dry to get it like glass. job done
its 1 in the morning iam off to bed lol
[Edited on 3/9/09 by oadamo]
Sounds good! My experiences have not been good with this either, and I have the same gun. I set mine to 40 psi.
Good info on there though, especially about the water, and running the hose up high.
Nice write up- cheers.
Haven't used my spray gun in anger yet but might be tempted to have a play, save money on all those rattle cans...
theres lots of good info on mig-welding.co.uk
http://www.mig-welding.co.uk/spray-painting.htm
The KEY information is in the middle of the article.
GOOD PREP work is VITAL.
Also no water in the airline!
You cant pay enough attention to the prep work. If you start with crap prep work, the finish can only be less than doing a good job on the
preparation.
Same goes for welding!
Now could someone post something that tells you what the different paints are, advantages / disadvantages / which will kill you?
great write up the finish is a little bumpy there, i think maybe turning down the air pressure might help that. i forget what air pressure i used
on that bonnet, but it was twice the pressure it should have been. i just forgot to turn it down...
Originally posted by oadamo
before you spray make sure there are (no) bits on the panel, make sure there are no bits on the panels. make sure there are no bits of crap on the panels lol. wipe the panel with the (Synthetic) thinners then run your hand over the panel and i bet you still have bits.you have to take your time wiping down.
Like MikeR I would find a brief note on the pro's & cons of different paint types very useful!
Originally posted by blakep82
great write upthe finish is a little bumpy there, i think maybe turning down the air pressure might help that. i forget what air pressure i used on that bonnet, but it was twice the pressure it should have been. i just forgot to turn it down...
you've not hesard of tack cloths then? these are small rag impregnted ewith some stuff - feels kinda waxy - that pick up the ickle bit without leaving gease or other contaminant on the surface.
I recommend them.
I'm not sure you can cut that paint back. I think it's a from the gun finish.
Neil
Tack cloths are the way forward.
When i sprayed my locost i put the paint on thickish so i could flat it back and buff.
Still havent done it and i painted it at christmas. Theres a couple of runs and the finish is crap. 1200 grit and g3 will sort it.
2 Pack: contains cyanide ,Great paint. ideal for killing off pesky rugrats and neighbours, not the slightest bit dangerous as long as you wear an air
feed respirator, most definately powered by another compressor outside and in the fresh air. illegal to buy for automotive use but most paint
suppliers have a notice up saying. Not for automotive use, ideal for doors, cabinets and shelving. very responsible I must say but what the hell,
tony
