Whats the best plasticy stuff to use for making hard windows for half doors and wind deflectors?
Iv looked in B n Q and the sheets of stuff they have is polystyrene? and says for interior use only? Is that the same as polycarbonate or what?
Cheap and off the shelf is best.
Woolies sell the right stuff?
http://www.woolies-trim.co.uk/c-101-window-material.aspx
Do you know of any online guides to making a roof / doors etc?
Whoops, sorry that link is for the stuff for rear windows.
Try Bay Plastics in North Shields http://www.bayplastics.co.uk/ very friendly and helpful bunch, who will deliver.
Mike
[Edited on 3/9/09 by Guinness]
Lexan - so it doesn't crack or go foggy in the sun
That woolies stuff is good but im thinking like 3mm. Im going to use ally for the bottom half with stiff plastic for the window. No need to have a
frame then and muchos easy to do.
I have nicked the idea from Piddy. He'l probably beat me up on sunday when i see him.
The yellow car here. They look a very nice idea.
[Edited on 3/9/09 by Danozeman]
http://www.plasticstockist.com/index.cfm?Page=cXVpY2tmaW5k&Keyword=lexan&Code=MC43NTExMg==
Lexan, but be aware it scratches easily, and don't even think of wearing Polarized sun glasses while driving, turns the scenery to look like oil on water.
Place in Cherry Hinton near Cambridge that sells Lexan if that's any help Dan. Engineering and Design Plastics . Sells offcuts as well
HI Dan.
Mine are made from makrolon. Do A search on the web for details.
Lully. Il give E and D a ring tomorrow and see how much they want. Gonna give ipswich plastics a gander aswell.
Hi Dan,
Just made my side doors and I used Lexan which is absolutely perfect. The specific type I used is 3mm thick FMR5XT which is designed for external
glazing and has 'high abrasion resistance' on both sides and is made by GE plastics. Should be able to get that from Ipswich plastics I
would've thought?
I'll be at Diss for the next meeting in a week or so, but I'm only based about 10 miles from Stowmarket if you want to come and have a look
at the doors.
Ed.
I'll be at Diss for the next meeting in a week or so, but I'm only based about 10 miles from Stowmarket if you want to come and have a look at the doors.
I went to my local "glazier" and got some "poly" same stuff they use in bus shelter windows. Can be cut with a saw drilled milled,melted etc. About 6mm thick Used it on my landorver to build the back of the truck cab.
