Boot Cover Advice pls
Dick Axtell - 10/9/09 at 05:25 PM
Will have to install a boot cover, for IVA requirements, (as was for SVA, I believe).
What material is recommended? Alu sheet, heavy gauge C/F sheet, or good ole MDF, covered in vinyl???
Will also have to fit fuel filler + cap into this cover.
02GF74 - 10/9/09 at 05:55 PM
^^^ all of those a good. depends on what parameters you a building to? want it to look nice? wnat it to be light? etc.
I would suggest 2 mm aluminium covered with pvc cloth.
not a fan of MDF which is solely for making crummy furniture and/or dog kennels
BenB - 10/9/09 at 06:12 PM
I agree MDF is way heavy and you really don't need the back of a 7 to be any heavier... (unless you've got a boat anchor at the front in which case it's a sensible precaution to stick an MDF anchor on the back!!)...
eznfrank - 10/9/09 at 06:50 PM
If you're using MK bodywork I'd go for a tonneau cover which nicely covers the rear > side panel join
bi22le - 10/9/09 at 10:03 PM
Fake carbon fibre sheet? Its light, cheap and looks ok.
Dick Axtell - 10/9/09 at 10:10 PM
Thank you, all, for these replies. Will check out the fake C/F sheet idea.
