Cutting Holes in GRP side Panels
big-vee-twin - 2/1/10 at 03:07 PM
I am planning soon to start cutting my side panels to allow the front wishbones etc. to come through.
Before I mess them up any tips that may help me avoid ruining them!
big_wasa - 2/1/10 at 03:41 PM
measure twice and cut once
AndyW - 2/1/10 at 03:42 PM
measure three times, cut once, and use masking tape so you can mark where holes etc are going to be before cutting...
Project7 - 2/1/10 at 03:52 PM
If you plan to use tank cutters/holesaws run the drill in reverse, it takes a bit longer but doesnt snatch and chip the gel coat.
[Edited on 2/1/10 by Project7]
Richard Quinn - 2/1/10 at 03:54 PM
Originally posted by Project7
If you plan to use tank cutters run the drill in reverse, it takes a bit longer but doesnt snatch and chip the gel coat.
Or get some decent hole saws and run the drill quite slowly until through the gel
Project7 - 2/1/10 at 03:57 PM
Sorry richard I editted the post just after you quoted me. I meant holesaws.
bodger - 2/1/10 at 04:55 PM
A Black & Decker power file is good for GRP - sometimes a bit too good, be careful with it.
austin man - 2/1/10 at 05:44 PM
a dremmel is also a good tool for the more inticrate shapes
rf900rush - 2/1/10 at 06:06 PM
I also found ceramic tile cutting jigsaw blades work well for large holes and straightish cuts.
And don't forget the masking tape to protect from scatches.
norfolkluego - 2/1/10 at 06:23 PM
Wear a mask, serious amounts of dust (there again I did use an angle grinder when cutting the hole for my carbs, mans tool, it's pretty quick too!)
Yorkie - 2/1/10 at 10:24 PM
As above, measure twice and cut once.
Take care when trial fitting the GTS side panels as they are a tight fit over the chassis rails.
