Stiff hinges
David Jenkins - 19/4/10 at 09:56 AM
I want to fit a couple of wind deflectors to the uprights of my windscreen to reduce the turbulence that whistles round the side of the screen - A bit like you see on Cobras.
The plastic bit is easy enough, but I was wondering where people had got the "stiff hinges" that allow the deflectors to be moved, but keep them in position when in use.
Alternatively, is it possible to get hinges that can be fixed/tightened once they are in the right position?
MakeEverything - 19/4/10 at 10:34 AM
Cant you use normal hinges with the pins, and then replace the pin with a small bolt to tighten i up?
David Jenkins - 19/4/10 at 11:06 AM
I'd wondered about doing that...
ashg - 19/4/10 at 11:20 AM
wack the hinge pivot with a hammer in a couple of spots that will stiffen them up
Marcus - 19/4/10 at 11:36 AM
I got some plastic friction hinges from RS components for mine, they were fine and allowed you to adjust the friction. There's plenty out there.
David Jenkins - 19/4/10 at 11:40 AM
I did a search for friction hinges - all I got were ones for double-glazing.
mangogrooveworkshop - 19/4/10 at 12:50 PM
david email me and i will sort you out with some bits.
Humbug - 19/4/10 at 01:41 PM
"real" friction hinges are available from Europa Spares, but only with Cobra-style wind deflectors attached... here
David Jenkins - 19/4/10 at 06:23 PM
Have you seen the price of those!
rusty nuts - 19/4/10 at 07:35 PM
Mine don't use any hinges, I made my deflectors by heating the Lexan and bending in a sheet metal bender . Too tight to buy hinges
MkII - 19/4/10 at 09:21 PM
Ive got a pair of them cobra stlye wind deflectors c/w hinges in the garage somewhere if your interested david .m.
Mix - 20/4/10 at 04:15 PM
Hi
Bellville washers may be what you're looking for.
Regards Mick
David Jenkins - 20/4/10 at 06:19 PM
I was wondering what you were on about - now I understand!
You were thinking of using them as springs to keep the hinge joints tight, I presume...
