my fiat 500 1972
thepest - 4/1/11 at 03:43 PM
Hello all, anyone got one of these? I'm wondering if there is a way to adjust the doors or the door strikers.. I'm having trouble getting them to close properly. Anyone worked on something similar?
rusty nuts - 4/1/11 at 07:47 PM
They never had the strongest bodywork even when new. It may be that the doors have dropped causing misalignment with the door catch, wouldn't be the first time I have used a trolley jack under a door to adjust alignment. If you try it open the door slightly, use a block of wood under the door and very gently jack it up . Release the jack and check fit, repeat several times if needed until door closes
thepest - 5/1/11 at 06:23 AM
I had a feeling it might be that way, cheers & thanks
