Hi all,
I hope you all have a buzz about the summer and the great days of driving ahead. I cant wait!!!
So, Im starting to mask up my rear tub to spray the arches. The problem being is marking tape dont like going side ways and creates creases which will
give a 50p effect edge. Any nifty ideas around this. Insulating tape instead? Some other method of masking around corners?
Thanks in advance,
Biz
What you want is 3m fine line tape, that stuff is magic
Yep, fine line tape and then the normal stuff.
Also don't leave it on too long as it's a PITA to get off.
Ah more money, I should of guessed!!!
cant you release the arches slightly or are they rivetted, if you can then do it and slide paper behind them
