Can anyone one help me out by telling me what dim. the scuttle have on the Book chassi, or even better a drawing.
[Edited on 20-11-04 by viking]
I'm making my steel one at the moment, what dimensions are you after?, I can give you my Turbocad drawings, can you read them in that format?
Mick
Well if you have a drawing it would be best, can you save as .dwg format?
Im using Solidworks and i´m not sure it can handle Turbocad.
Viking, this LINK is from the locost site over in OZ.
A rough drawing but it gives you an idea.
ATB Dan.
These are the dimensions I worked to. I'm using a book chassis with MK nosecone and Zetec engine.
Mick
Thanks guys.
Mike the .dwg came out perfect.
Do you know the difference on the height between your Zetech and a Pinto?
For those who needs to compare engines.
Sizes (height, length, weight and with)
+ horsepower and general tuning.
take a look at the www.westfield-world.com
There is button where you can compare engines (and its quite good)
good luck
Ricky from DK
