Hi all,
I may be wrong here but I recall someone mentioning to me that you manipulate the fibreglass by heating it up with a heat gun. Does this work? I have
thrown all of my spare bits to try it!
Thanks,
it does work but if your not carefull it bubbles if it gets to hot.
I suppose the only option is then to bubble the rest of the car!
i suppose if you want something that bit different.
I suppose I wouldnt bother
i suppose your right
Mmmmm it tends to go woof with a bit to much heat
Shug
Howlor, which part is it your looking to bend?
I remember Marc spoke about it in a thread previously when discussing the nose-side panel fit
Rich
It depends on the resin used. Polyester based resins are a thermoplastic, and will soften and bend with heat applied up to an extent. To much heat will result in the aforementioned blistering and destroying of the resins properties. If epoxy is used, it is a thermoset resin, and will continue to harden with the application of heat (post cure if you will) until its max temperature is reached and then it will melt (not in a good pliable way). Cheers!
Rich
This is the thread I was thinking of.
Do you have any pics of what it is you are trying to do, I note a few people have mentioned fitting the nose to the sides
Rgds
Rich
Depends what you are after doing, but it is possible to alter the shape. Clamp it where/how you want it then something like a painters oven with a bit of warmth rather than direct heat......it does work as ong as you don't go mad.
