Painting Brake Drums
rpsmith - 29/6/06 at 10:57 AM
Does anyone know, or has painted brake drums with standard metal paint rather than high heat paint, i don't really know how hot the brake drums get?
Richard
andyharding - 29/6/06 at 11:11 AM
Hammerite will be fine.
rpsmith - 29/6/06 at 11:13 AM
Is it only calipers that get really hot?
Winston Todge - 29/6/06 at 11:15 AM
Calipers have been painted with Hammerite too, without any reported problems...
02GF74 - 29/6/06 at 11:20 AM
I've sprayed mine with silver hammerite type a paint, inside and out but obviously maksed off the surfacface the shoes touch
that paint should be good to about 200 C - can;t see that I will get them as hot as that ... but time will tell.
ch1ll1 - 29/6/06 at 11:21 AM
i have just painted mine with coach paint (same colour as car )
i know im sad !
done about 100 miles no probs yet !
[Edited on 29/6/06 by ch1ll1]
Bluemoon - 29/6/06 at 11:38 AM
As far as I can make out it's less of a problem than people think, but the paint may discolor with the heat. I have painted mine with chassis black so this should'nt be a problem.Time will tell.
Dan
nige - 29/6/06 at 11:38 AM
ive always used ordinary gloss
non drip for better cover and no runs
wyatt - 29/6/06 at 11:52 AM
Hammerite lots of nice colours
Avoneer - 29/6/06 at 03:30 PM
Plasicoat ceramic paint.
Small pots (like baby food) from B&Q for a couple of pound.
Comes in a million colours including fluor's and chrome.
No problems here.
Pat...
RichieC - 29/6/06 at 04:18 PM
Yep another vote for hammerite. I had assembled my drums back plates on the wrong side of the hub so they were touching. They were glowing red hot within a mile and the paint only just started to burn off then and the heat damage was very localised.
Pretty resiliant to heat, more than adequate for drums.
Rgds
Rich
[Edited on 29/6/06 by RichieC] Rescued attachment Hot Drums 1.JPG
UncleFista - 29/6/06 at 05:05 PM
The main (only?) advantage of the proper "caliper paint" is, it's unaffected by brake fluid.
Hellfire - 29/6/06 at 07:53 PM
It's actually brake fluid resistant, not brake fluid proof. It also repells brake dust very easily... not that it matters that much.
MikeRJ - 3/7/06 at 12:15 PM
I used engine enamel on my calipers and drums and never had a problem. Small pots from Halfords or Frosts are quite cheap and available in most of the standard "brake caliper" colours, e.g. black, red, yellow etc.
TimC - 10/11/06 at 07:02 PM
Ok, spray or bruish paint calipers??????
DarrenW - 10/11/06 at 10:11 PM
I had my old drums and loads of other donor bits professionally rust removed and zind primed. Allwere then etch primed before spraying with silver smoorthrite. No issues 1 year and 3,500 miles on.
Drums have since been sprayed with std satin black spray and look great so far.
