job done; decided to pull off the carbon fibre plastic sheet, acid prime and paint in black (going for a black/red theme; yes, I should have painted
the bonnet black too instead of hand polishing for weeks but ....),
I mean, stainless is so all very common
... and since I had the sheet already cut, then might as well use that in locost fashion
arch protectors
Looks good.
Whats the name for the type of edging strip you have round your bonnet intake cutout? I've looked around but can only find the larger herringbone
type stuff.
Originally posted by Alfa145
Looks good.
Whats the name for the type of edging strip you have round your bonnet intake cutout? I've looked around but can only find the larger herringbone type stuff.
