Goodyear Eagle F1 255/35/ZXR18 mudflaps
Humbug - 12/8/06 at 11:31 AM
I recently changed my cycle wings and had the brackest repaired and strengthened. I fitted the new wings and decided on some new mudflaps instead of the old ones (cut from truck mudflap).
I went to the local tyre place and begged a scrap tyre with an interested tread. Cut the bead with an angle grinder, cut the side walls off with a jigsaw, and cut the flaps to shape from the tread bit. I think it looks quite good, though the flap needs to settle down a bit.
I did think of putting some on the front of the rear wings as stone protectors, but that might be a bit overkill? Rescued attachment 2006-08-12 1 ST new mudflap.JPG
graememk - 12/8/06 at 11:33 AM
now that is locost............tight arse
Humbug - 12/8/06 at 11:34 AM
No fair... I spent £1.20 on new nuts and bolts ;D
scutter - 12/8/06 at 11:39 AM
I like. So good an idea i may have to just copy.
Simon, I'll get down the garage tuesday and measure the seats for you( it's the next time i'm allowed down there).
ATB Dan.
Humbug - 12/8/06 at 12:07 PM
ATB Dan.
Well, Dan, it was kind of your idea - you mentioned the tyre cycle wings on the Vanwall. I've still got a fair bit of tyre left, so I could bring a piece to the next Newlands meeting if you want it? Let me know
...btw, remember I said one of my cycle wings was wobbling more than the other? I found out why yesterday - the rear tube on the right hand bracket was cracked half through just where it joins the plate. I rboke it right off, then used Araldite Steel adhesive and a cut-off bolt that just fitted into the tubes. Hopefully it will stay put :~)
Peteff - 12/8/06 at 12:07 PM
It's like the tyre patterned carbon front cycle wings on the Vanwall lookalike kits to maintain the appearance of open wheels. I made some trailer mudguards in a similar fashion. They'd make good looking stone protectors if you get wide enough tyres.
the_fbi - 12/8/06 at 12:23 PM
Aren't the shocks adjustment controls supposed to be on the inside of the shock?
Humbug - 12/8/06 at 01:02 PM
Dunno - they were like that when I bought the rolling chassis. They seem to adjust OK and the suspension works
BKLOCO - 13/8/06 at 05:49 AM
Why???
David Jenkins - 13/8/06 at 10:12 AM
Mine are in the same place - works for me, and no-one's complained. The only advantage in having them facing the bodywork is that you wouldn't have to put a rubber nut cover over the adjuster to keep Mr SVA happy. They're easier to adjust where they are (not that there's much in it).
the_fbi - 13/8/06 at 10:17 AM
All the various types I've owned have always stated that the adjusters should be on the inside in their install instructions.
AVO, Spax, Protech, Koni.
I'm no shock expert so I ain't going to argue with a manufacturer.
procomp - 14/8/06 at 07:04 AM
Hi it also means that any water will run of and away rather that get in to the adjuster and eventualy sieze it .
cheers matt
