Can anyone suggest what to use to seal around the nose and scuttle under where the bonnet sits? Ideally something that will compress a little to form
a bit of a seal?
Hi, Most people use self adhesive foam rubber strip, we got ours from MAC#1.
Simon
http://www.woolies-trim.co.uk/sponge.html
Mike
Great, thanks for the help!
I used the foam tape. Works well but does tend to move in use. I have some areas around bonnet and nose cone that would benefit from re-applying after 9 months / 3000 miles.
hmmmmm, interesting one this!
I now work for the main international manufacturer of extruded rubber automotive sealing systems!!
Got some great seals just perfect for locost bonnets!!!
