What is available to seal the lower edge of the screen to the scuttle?
I believe that J C Whitney do a range of rubber extrusions in the US or Wollies in the UK do mail order.
Chris
lolocost do a seal £5 http://www.lolocost.co.uk/
This is one of those things that C*t*rh*m actually sells at a reasonable price (also fender piping and a few other odds and ends).
If it bunches up where you have your "V", maybe you can cut it and use RTV sealant to splice it together.
Pete
THere is an insulation tape that is sold at Home Deopt (rubadex) for about $5 that is easily cut and holds up very well. I've used it on a ton
of stuff, and could bring some over if I come by.
unless you've allready mounted the windscreen, haha
-MR
