panning to make 5 small holes in my plastic screen (thought it was glass) to attach tax disc holder - any reason why not to do that?
Also using pu adhseive to attach rear number plate - any reason not to to that? (I will be able to drill 2 holes for plastic bolts at the top but no
access further down due to tank/boot floor)
on the back why not pu a number plate holder on from a boy racer shop then stick the plate to that
graememksva4
[Edited on 12/4/07 by graememk]
Why not use a motorbike tax disk holder?
boy racer plate holder = excess weight and spending cash
only problem I can tbk off is if the reflective plate backing starts to peel .... may use rivnuts + plastic bolts.
already have the tax disc holder - did consider bolting to scuttle side but it is not flat enough (or maybe between the seats).
boy racer plate holder £5 tube of pu £8?
Fit the rear no. plate with self tappers and bolt the tax disc on the rear bulkhead between the seats
Hi,
we PU'd our rear number plate straight onto back panel with no problems.
Also fitted a motorbike style tax disk holder into side of the passenger footwell to try and keep it out of the way if it rains etc.
Ed
you can buy proper double sided numberplate tape, i've allways used it with no problems.
