Hi All,
I have been entertaining the thought of making a see through bonnet for show. Has anyone ever done anything like this?
ACRYLIC - Perspex ® / Altuglas ® SHEET
The main properties of Acrylic - Perspex ® / Altuglas ® sheet:
* The appearance of Acrylic - Perspex ® / Altuglas ® sheet
* The ability of Acrylic - Perspex ® / Altuglas ® sheet to transmit and reflect light
* The transparency of Acrylic - Perspex ® / Altuglas ® sheet
* The exceptionally long exterior life of Acrylic - Perspex ® / Altuglas ® sheet
* The ease of use and processing of Acrylic - Perspex ® / Altuglas ® sheet
* The good mechanical properties of Acrylic - Perspex ® / Altuglas ® sheet
* The high acoustic and electrical insulation of Acrylic - Perspex ® / Altuglas ® sheet
* The resistance to high temperature of Acrylic - Perspex ® / Altuglas ® sheet
* The Recyclability of Acrylic - Perspex ® / Altuglas ® sheet
* The good food contact use of Acrylic - Perspex ® / Altuglas ® sheet
O
[Edited on 21/8/07 by Omni]
Hmmm- polycarbonate vacuum forms quite nicely if I remember correctly. I've seen people make wooden tools by hand...
I did think about using it for the floor! Change plan when I thought about road-kill smeared across it!
Adrian
It would look pretty cool hey?!
LMAO at the floor idea, yeah it really would be road kill galore! It would mak eyou feel ill I would have thought too!!!!
I have found a couple of companys that make things out of this. I am going to mail them and get some quotes (just for ref purposes)
O
Well you could just do the pasenger floor!
Adrian
Not so good for a bonnet as it would go floppy over the exhaust manifold.
Wonder if polycarb floor would get through SVA (can't see why not, but you might need tensile strength figures etc to prove it's strong
enough, certainly an intriguing idea
Most fireblade exhausts exit out of the side panel anyway.
I don't think it would get so hot as to go floppy but it might discolour.
Vacuum forming is easy if you have a mould. You'd need a good vacuum to pull thick enough stuff to make a bonnet though.
A polycarbonate floor. nice. What if you make the whole bodywork out of it. What coulour would you put on your V5?
Oh now look! you've made me want a clear car again!
LMAO @ Smart51. Go on, do it! DARE YA'
O
Poly carb would be a good material s it is very resistant to penetration though very heavy strength for strength with ally or steel. If you think
polishing scratches out of ally is not fun then you will really hate trying to keep polycarbonate shiny, any dust will start scratching or sand
blasting the surface! Cool look though! Vac formes lightweight wings in poly carb would be a good idea.
Caber
Wrap the headers in "Exhaust Wrap" and then fab up a small polished (removable if you want!) sheild to direct the heat away from the bonnet,
and then with some strategically placed holes drilled to increase airflow in/out/through/over it might stay cool.
I say that in spite of the fact that mine is always as floppy as hell () when I come to a stop...
Originally posted by worX
Wrap the headers in "Exhaust Wrap" and then fab up a small polished (removable if you want!) sheild to direct the heat away from the bonnet, and then with some strategically placed holes drilled to increase airflow in/out/through/over it might stay cool.
Anyone go a PDF of the book bonnet dimentions?
O
Already done - all over bodyshellLotus Expose
[Edited on 21/8/07 by JC]
Well the proper way to show off your engine is to fit one so large that there is no hope of fitting it all under the bonnet .
At least thats how hotrodders do it here.
Seriously though, Id say the poly bonnet will be very heavy, scratch, and distort from heat. The clear floor idea is neat. Ive driven trucks with
large rust holes in the floor before..... it's interesting.
Cheers.
I'm starting to regret not doing the floor in poly' now!
Adrian
i was going to do a polycarb bonnet, i wanted to be individual and unique i guess that won't happen now. besides, i'm sure its been done before
Here in mexico I have seen VW bugs with transparent engine covers.
I think they resist heat some, but must be a bi**h keeping them scratch free.
Cool, i thought about doing my side panels in something clear, but then again i am weird and was most probably drunk at the time....!
Carl
