Progress Update
Davey D - 4/1/09 at 06:35 PM
Ive finally got my finger out this weekend, and got on with some of the last finishing touches needed to get the car done (still needs SVA-Friendly bits doing though)
Sorting my paperwork out now. Hoping to get it to MNR for checking over/SVA bits end of jan and SVA some time in feb
Looks something like this:
speedyxjs - 4/1/09 at 06:38 PM
Very nice
Do the indicators need to be a bit further out?
eznfrank - 4/1/09 at 06:38 PM
Nice looking car mate, there are obviously SVA bits to do but doesn't look like too much.
twybrow - 4/1/09 at 06:39 PM
Looks lovely. Nice build there Davey. Good luck at SVA.
nitram38 - 4/1/09 at 06:41 PM
001Ben - 4/1/09 at 08:34 PM
looking great
paublo999 - 4/1/09 at 08:41 PM
looking good
scoop looks lovely, haven't managed to do much on the car but you could help by letting me know how you got on cutting the hole in the bonnet and also fixing the scoop? It looks like the carbon mods one..
Paul
paublo999 - 4/1/09 at 08:43 PM
also - are you not missing a reverse light?
sucksqueezebangblow - 4/1/09 at 08:58 PM
Looks fantastic!
Davey D - 4/1/09 at 08:59 PM
Yes it is the carbon mods scoop.
To fit it i measured up where i wanted to fit it it, then drew around it.
I then drew a line 20mm in from the outline of the scoop.
Next i cut out the big hole of the inner line with a fine blade jigsaw giving me 20mm of overlap between bonnet, and scoop.
on the underside of the scoop i bonded 7x bolts so i could bolt the vent into place.
once the bolts had set i drilled the holes out of the bonnet so i could bolt the scoop on.
i then run a bead of tigerseal round the bonnet where the scoop sits, and i then bolted it into place.
once the scoop was on a ran more tigerseal along the inside just to make sure it was stuck down well
MK chippy - 4/1/09 at 09:57 PM
Looks awesome! Like the little extension on the aeroscreen.
Reverse light?
clutch_kick - 4/1/09 at 10:21 PM
Brilliant!!!
Davey D - 4/1/09 at 10:25 PM
i was of the understanding that you dont need a reverse light?
adithorp - 4/1/09 at 10:38 PM
You don't!
adrian
Winston Todge - 4/1/09 at 10:42 PM
Looks brill Davey!
Just doing the finishing touches to mine also... Really like the scoop on the bonnet. That was from carbonmods.co.uk then? Definitely gonna pop one of those on... Looks proper nice.
Tidy build diary bud. Good luck with the SVA!
Chris.
jambo - 4/1/09 at 10:49 PM
car looks great mate well done.
Winston Todge - 4/1/09 at 10:50 PM
Where did you source your OMP SuperQuadro from by the way? What boss did you use? And have you got any pics of the install?
Ta bud,
Chris.
Davey D - 4/1/09 at 11:41 PM
The wheel, and boss was supplied by MNR
richardh - 5/1/09 at 03:05 PM
very nice
TimC - 5/1/09 at 06:42 PM
Looks spot-on. Fancy finishing mine when you're done?
I've not seen the MNR in 3 months!
bassett - 5/1/09 at 07:52 PM
Nice work as it looks great. Mine should really be at a similar point but isnt and im really hoping to make sva rather than iva
Johneturbo - 5/1/09 at 10:31 PM
Cracking job Davey, love the yellow and black great contrast in colours.
now get it on the road for all to see
Pdlewis - 6/1/09 at 08:37 PM
Looks super nice.
What did you use for the exhaust strap/where did you get the rubber for the strap from?
sorens2 - 6/1/09 at 09:36 PM
Cool car.
Canīt wait to get mine later this month.
Soren S2
Davey D - 6/1/09 at 11:10 PM
Originally posted by Pdlewis
Looks super nice.
The exhaust strap i made from aluminium flatbar. After struggling to find one ready made big enough to go around the exhaust i thought stuff it, and made it myself.
the bit underneath the strap isnt rubber... its some exhaust heatwrap as ive got loads of it spare
