How much protection does the aeroscreen actually provide? I'm hearing mixed reports, some say they are suprisingly effective at diverting the
wind and flies over your head, others are saying they make little if any difference.
So what are your experiences/thoughts?
Mark (newbie)
it all depends how tall u are .i only get the wind hitting me from my nose upwards and i am 6 ft 1.and i have seat runners.but my brother is shorter and the wind is almost over his head .i would say they make a difference to none at all
Mine really works, it does exactly what it should do and deflects the wind straight over my head. Although I am 5ft10 and my seats sit a little lower
than Iain's.
I wouldnt go back to not having one
bang on 6ft and with slimline runners mine doesnt work unless i scouch right down
better than without by far though but not safe for driving without decent eyewear on sub 40mph short distance or otherwise with a lid
mine is perfect but my seat is not on runners. am also only 5 foot 10
i have tried driving mine with, and without the aeroscreen, and there is definately a difference.
im 5'10 and have seat runners. with no screen the wind hits me from my neck upwards which you can really feel with a helmet on, with the screen
fitted the wind hits me just at the top of my forehead which is much better
Thanks guys, I'm bang on 6ft and I'll need a seat on runners which will put me a little higher again - hmmmm
Looks like i will definately be needing one!
I used seat runners from a mk3 fiesta. They have the ones that only actually lock on one side so I got both the locking sides so one from each seat. I
faced both handles inwards so they pointed at each other just under the seat and then found a nice bit of ally tube at B&Q that joined both
handles together, push fitted on. They only added 20mm to the seat height.
My aeroscreen did make a difference.
Maximil666 have you got runners? im also 5'10 but wondering how much of the car il actually be able to see enough of the car once the screen is
on?
Adam
Hello mate, I can come round and give you a demonstration of what its like without one ATM.
