After having my diffuser sitting in the garage since the Autosport Show, I finally decided to get my butt into gear and get it fitted (I’m sure the
sunny weather influenced my decision!)
i like that where is it from?
I need one of them in my life!!
Where from and how much please.
Biz
It is from MNR, if I remember correctly it was £175 but will check
ETA: Yes it was £175 inc VAT
[Edited on 19/3/11 by spdpug98]
That would be why it fits your car perfectly!!
How has it been fixed on?
that looks very nice mate... might spend some brass and treat myself...
How far under does it go? is the rest of the undeside nice and smooth?
Looks great! I have one in the garage also. Could you post some pics of how you fixed it to the car? Thanks in advance.
Thats great. Thanks for doing that. I might change the alloy strip for a couple of hinges so removing the side bolts will allow the diffuser to drop incase access is needed to the diff etc.
Hi, fitted mine at the weekend (at last).
rivetted the ali strip to the floorpan, then the diffuser slips into
the gap between the ali strip & floorpan. Diffuser held up at the
back by 4 bolts through the diffuser into rivnuts in the bottom lip
of the back panel. Just remove the bolts to remove it.
Mine is also higher up, as it it fitted around the back panel
rather than under it.
Will try to remember to take pics......
