Hi guys,
Just getting started with my Vortx kit over here in Holland. For some reason, it is arriving from my agent in pieces and the instructions I have are
rather poor.
Can someone give me an idea of how many rivets are required to attach the big, one-piece (1.5 mm aluminium) belly pan to the round tube frame? I have
a bag of 80 rivets which may well be for that purpose, but there is no labelling so I'm not sure.
Itching to make progress!!!
Thanks,
Steve, in the NLs
Similarly, does anyone have pix from below the car, when it's up on a lift, so I can get an idea of the rivet spacing? Just wanna know if I need
one per inch, like airplanes or one per 150 mm since it's not too stressed, will be further stuck on by polyurethane and I don't want to put
any more holes in the chassis than necessary.
I think most of you received your chassis with this work already done at Harrogate, but mine was worked over, here in NL and then powder-coated
afterwards. So, I must attach the floor pan myself.
Thanks, again,
Steve, in the NLs
Give Chris a ring, he will tell you the correct spacing required.
Here's a picture of my floor panel. Not the best one but it'll give you an idea. The panels were also glued uring PL 400.
Thank you Fege!!!
Wow - that's indeed about 1-inch/2.54-cm spacing. Ugh - gotta go buy a bunch more rivets!!!
Let me ask you - is that your work or is that what MNR delivered pre-assembled?
Thanks again - you're my new best friend!
Steve, in the NLs
Here's mine, after cutting floor to shape, marking, drilling, deburring and riviting. The outside edges were done after the sides were fitted as
they have a 2" lip that curves under the floor. Big headed rivits. Looks like 3" ish spacing.
That's my own work! My arms looked like "Popeye the sailor man" as I was using a regular manual riveting tool...
[Edited on 8/10/12 by fege]
Thanks y'all!!!
We got the floor riveted (175 of the damned things!) and glued on last night.
Now I gotta build a stand so we can flip it over and continue. Stay tuned!
Steve, in the NLs
