We went up to MNR today to have a look over the kit and get an idea of exactly which kit I might order and what extra bits I might need.
We walked out having had the alignment sorted on my wife's car and £500 lighter having ordered an RT+
Now I get to start buying bits
Congrats, what's the lead time on your kit likely to be?
Good choice mate congrats
Does the RT+ come with the lighter T45 chassis? If not, find out how much extra it is. It is quite a lot lighter and I wish I'd chosen that option.
Marc will mix and match RT, RT+ and Super versions of the car if you ask. I didn't know this (or that there was a thinwall T45 version of the
chassis) when I ordered mine, like I didn't know that you could have an RT+ without the full cage.
My point is that a thin wall T45 chassis is a lot lighter than the standard one. You don't have to pay for the full "super" spec to
get it. Even is only half of the tubes in the RT+ chassis can be replaced by the lighter ones, there is still a good weight saving to be had and
probably for not much extra cash.
Really, I'd speak to him about it.
Whats the point in buying a t45 chassis and then crippling it with outboard suspension and sierra uprights????
If you dont buy the Vortx Super in its entirity you are better off with the RT+ and ally uprights...
That way you keep the lower UNSPRUNG weight and rising rate suspension...
You are getting obsessed with power to weight Smart
Originally posted by G.Man
You are getting obsessed ... Smart
I just wish it were faster still Talked to Chris about this today.
The RT+ rolling chassis is approx 30kg lighter than the same RT as a rolling chassis.
The RT+ in T45 would be another 20kg lighter than the standard RT+ but the cost difference is quite high!
Although I'm all up for keeping the car as light as possible I really can't work the additional expense into my already tight budget.
My car was built to a cost as well; not that it was cheap. all things are worth considering, even if you decide against them.
