there will be an area set aside for mnr owners at harrogate, including a 10 x 4 metre awning incase the weathers iffy,
best regards
marc
am I allowed to park the passat in there as the V8 still no spark .
Argiv8
whats the date for this?
russ
This weekend Russ.
I should be there. Any other MNR owners driving to Harrogate?
rjbrookes - 7/8/06 at 10:43 AMcount me out then
roadboy - 7/8/06 at 11:46 AMWe will be there on the MNR stand with our freshly completed VortX, well we hope it will be completed by Friday, nearly done , just some trim to finish off.
See you all there.
Regds
Ian
Agriv8 - 8/8/06 at 08:11 AMWe have a spark
I was allowed an hour in the garage away from Kitchen fitting duties ( yes I was sulking !!!! )
After finding a hidden Condensor in my opus dizzi system I have a spark (earther through right index finger OOOuch )
replaced with a spare condensor from a pionts distributor are they all the same ?
dont know how long it will last will have to go for a test run tonight ( the old one has a date stamp of 1983 )
Regards
Agriv8
marc n - 8/8/06 at 09:07 AMgood stuff
i will get the trailer ready then
mnr laptop - 9/8/06 at 05:47 PMis it fixed iain ????
Agriv8 - 10/8/06 at 08:10 AMNope.
Need a play tonight got some details to remove the Rover gubbings from the box of tricks leaving the GM unit that does all the work.
PS broke the push rod that goes to the clutch master cylendar after missing the Brake when we were heading for an incident of the back of the recovery truck
but just in case can you get me a set of points and a condensor for a carbed 3.5 range rover old 'S' reg vintage should be about right ( always best to have a backup plan )
Regards
Iain
marc n - 10/8/06 at 10:12 AMthere is a new module , points and condensor arriving here after lunch
Krismc - 10/8/06 at 04:51 PMsee yas there!
wont have a car but will be fun all the same.
Robert Ryan - 10/8/06 at 09:01 PMBilly and me are both coming along Sunday. Both cars are nearly ready for SVA, Going to buy a new brake system, hope I can get something cheap on Sunday.
Any advice on brakes welcome. (Sierra)
