I have tried to set up the ride hight on the rt + inbourd and it seems realy low (70mm)at the front.
set the springs high, still around 75mm
(Help)
Eh? You got 5mm extra ride height by screwing the seats all the way up?
I think I got 30mm doing that... Max'd them out though....
75mm is a bit harsh on UK roads.... I run 90mm and even then take it pretty carefully over speed-bumps...
That's too low for road use, especially if you sump is lower than your chassis. My sump is at 75mm, but the chassis is 120 front and 125 rear
(with me in it). That's as low as i'd like to go for road use.
[Edited on 11/3/07 by Phil. S]
The pushrod lengths are fully exstended.
still 75mm off the floor.
Put the wheels on, you cant drive around on the brake disc's.
Ray.
Check with Marc, you may need longer pushrods, I think they made some different lengths.
HTH
Ian
Doesn't it depend on the size of the wheels??
