MNR Floor Mounted Pedal Box
Pdlewis - 31/8/08 at 05:51 PM
Hello,
Been dicking about in the garage today and Im thinking ive not assembled the pedal box proply. Does anyone have a picture of it assembled specifically which way arround the bias bar goes and which m/c connects to which side?
looking at mine it looks like i have just pushed the bearing in, in no specific way
Paul
stuart_g - 31/8/08 at 06:40 PM
Here's a pic of mine. Front master cylinder goes to the shorter side of the balance bar (left side looking at the photo, right side looking in from the engine bay). Rescued attachment P1010105.JPG
Pdlewis - 31/8/08 at 06:45 PM
Thats great stuart couple of questions,
Is the bearing in the middle or just in the tube?
Whats the deal with those nuts have they got some sort of pin in them?
Werner Van Loock - 31/8/08 at 07:34 PM
pins are needed for SVA
stuart_g - 31/8/08 at 10:18 PM
start off with the bearing in the middle of the tube. You can then adjust either way when it comes to setting up the bias at a later date.
The nuts and roll pins are to lock the bias bar for SVA.
Don't worry about doing this bit yet, you need to drive the car and set the bias up first.
