HI, I'm after a foam filled or baffled locost shape alloy tank, does anybody know where to get one?
locost rough size: 550mm wide, 250mm tall 180mm deep
OBP tanks are the correct size, but don't specify foam filled or baffled.
Rally design don't have the corrcet size.
We have issues with the existing MNR one.
Cheers Gareth
Deneo on here makes 'em, and his work is top notch, very reasonable rates too
Welderman (Joe) made my tank. Baffled and made to custom dimensions. Top chap and top value too.
Try here allyfab
Cheers for the replies chaps, ill get in contact with one of the names mentioned to fabricate me a tank.
Gareth
What issues are you having with the MNR Tank?
