Tank fittings
Jasongray5 - 8/12/09 at 10:36 AM
Hi guys,
Im not too sure if this is in the right section but here we go?
Im about to make my fuel tank, and was just wandering what tank fittings you guys have used? Im not sure wether to make my tank out of steel or ally? but stuff like intakes, returns and filler pipes?
Cheers Jas Gray
blakep82 - 8/12/09 at 12:23 PM
carb or injection?
for carb you need:
a fuel outlet
fuel filler neck
breather outlet
for injection you also need a fuel return
Jasongray5 - 8/12/09 at 02:49 PM
sorry, injection tank.
Where about would I go to get these said fittings though please?
blakep82 - 8/12/09 at 03:54 PM
oh yeah, in the efi forum too
mine are just tubes welded in. the filler neck is just one of these welded on
http://www.merlinmotorsport.co.uk/p1791/SCREW-CAP-1:3/4%22-(45MM)-O.D./product_info.html
outlet and breather are just 8mm o.d ali tube with a bead welded in.
if i go out there tonight i'll try and get you a photo
[Edited on 8/12/09 by blakep82]
Jasongray5 - 9/12/09 at 07:01 PM
cheers blake
