GSXR injectors
lotusmadandy - 28/1/10 at 07:43 PM
Hi all,
I am planing to fit a set of k4 GSXR 1000 throttle bodies to my 2 litre zetec.Does anyone know if the injectors will flow enough fuel for the zetec?
scootz - 28/1/10 at 07:45 PM
I would say they will be more than adequate!
Miks15 - 28/1/10 at 07:48 PM
I would imagine so, the GSXR runs 180 odd HP?
Should be more than enough for a zetec
lotusmadandy - 28/1/10 at 07:49 PM
Cheers Scootz,Miks15.that was quick!!
[Edited on 28/1/10 by lotusmadandy]
will121 - 28/1/10 at 08:25 PM
think they are flow rate of 270 equates to be good for about 200bhp good previous thread link
matt_gsxr - 29/1/10 at 06:46 PM
These can yield higher car BHP than bike BHP as 0.9ms is needed for the (opening+closing). Lower peak RPM means less "wasted" opening and closing time. So, whatever BHP you can get in the bike you can get more in the car.
On this same point, if you go for more than 1 squirt per cycle you get to the maximum flow rate earlier (as you are opening and closing more often). Just something to think about if you are planning on a clever injection approach (i.e. sequential). Mine ran better at low RPM on 2 squirts per cycle.
Matt
lotusmadandy - 29/1/10 at 08:03 PM
Thanks for the advice guys,my mind is made up now to use the bike injectors.
Jenko - 3/2/10 at 10:00 AM
And just to 100% confirm this, I'm running 200bhp on the GSXR600 injectors!!!....Which are around 240cc
Paul.
