Further down the path, but still not running. I've posted a video here
http://picasaweb.google.com/lh/photo/L9u17vskyu3gjg9dHabvhg?feat=directlink (pick the HQ option) to show what's happening.
The HP fuel pump primes, I crank the engine and the injectors inject. Sparks spark but the engine doesn't start , it tends to bog down, goes
'phut' and something blows out of the inlet manifold.
What is the most likely thing(s) I've stuffed up?
Regards,
Dave
timing?
Definately got 12v to Megasquirt/edis/coilpack/fuel pump when in crank? (not just run)
Regards
Rob
might sound silly but you got enough fuel going in?
[Edited on 15/5/10 by omega0684]
spark too early ? sparking while the inlet still open
Spark plugs wet ?
regards
Agriv8
HT leads not connected to the right cylinders?
Can you put up a link to your MS map.
sounds like its sparking too soon.Chect the cranking settings on the MS
are you 1000% certain the VR sensor is in the correct position on the trigger wheel.
I am still a few weeks off starting mine.
Paul
Thanks guys. I found I had the sides of the coils crossed (A was B, B was A, C was D D was C) which was probably the cause of sparks with the inlet
port open. I also had a small leak of petrol and managed to spray myself with petrol fixing it so I've given up for the night now I've had
a shower
Right now I suspect pretty much everything I've done. Timing may well be out as I based the trigger wheel position based on the marks on the
damper. I assume this is probably correct as it is located by a woodruff key. I'll try again tomorrow.
