Duratec and R1 injector question
newton001 - 18/6/10 at 04:34 PM
Can anyone tell me if these two injectors are high or low impedance?
Stock Duratec 2005
Stock Yamaha R1 1000 2005
If not, any way to determine impedance?
Thanks in advance for any help.
big_wasa - 18/6/10 at 04:52 PM
Both will be high Z
MakeEverything - 18/6/10 at 05:03 PM
Stock Duratec 2005
You measire impedance (Resistance) with an ohm meter.
BenB - 18/6/10 at 10:35 PM
Stock Duratec 2005
Not strictly true but it'll tell you if they're high or low depending on whether the ohmage is a few ohm or 15(ish) ohm.
matt_gsxr - 20/6/10 at 09:59 PM
Just to clarify.
High Impedance are around 13 to 15 Ohm.
Low Impedance are maybe 3Ohm.
You can measure these with a standard multimeter.
