Heat insulation material - Carbs to Manifold
r1_pete - 13/8/10 at 08:02 AM
Ok its not quite a fuel injection post but....
I need to make some insulators up for the temporary carb setup I'm working on, does anyone know a supplier of either the plastic used by some manufacturers, or the thick paper/fibre stuff used between carbs and the manifold?
I need something in the order of 5mm thick.
Anyone know what the materials are called, and / or a supplier?
[Edited on 13/8/10 by r1_pete]
snapper - 13/8/10 at 12:52 PM
I think it's called Phenolic, a glass/resin compressed gasket that stops heat to the manifold from the block
snapper - 13/8/10 at 12:55 PM
Found it
Here
coyoteboy - 13/8/10 at 01:56 PM
http://www.directplasticsonline.co.uk/PTFESheet/0.5mm/
snapper - 13/8/10 at 04:41 PM
You'll want thicker than 1/2 a mill to be effective
5 mm min to 10 mm
5 mm min to 10 mm
coyoteboy - 17/8/10 at 10:36 AM
It was more the link to the source, rather than the actual product (I just grabbed it from my bookmarks as I've used that on other projects).
