megasquirt -lc1
Paul (Notts) - 23/9/10 at 04:23 PM
How do I check that the megasquirt is set up to use an LC1 sensor ?
Paul
[Edited on 23/9/10 by Paul (Notts)]
scudderfish - 23/9/10 at 05:27 PM
If you're using TunerStudio its File/Project/Project Properties/Settings
mark chandler - 23/9/10 at 05:41 PM
You need to go to file configurator and check that its set here for LC1, if not then go file directory and amend here:
C:/Program Files/MegaSquirt/car1/mtCfg/settings.ini
In EGO control settings to wide band.
Paul (Notts) - 23/9/10 at 06:05 PM
cheers
