I am making up some HT leads I have some silicone carbon core cable I have cut the outer insulation off and the core has a separate insulation around
it do I also need to cut this off,when this is done the small carbon cores come out.Do I crimp terminals onto the carbon strands or leave the
insulation on the cores and crimp onto this.
Hope this makes sence.
Thanks in advance Matty
I would strip back enough of the insulation so that the core could be turn back along the outside of the insulation under the connector. Some cheap crimping pliers have a section for HT connectors
IF there for IVA have the cable got the right markings ? if not this post may save you some time
Thanks for the advice I have now made up a set using vehicle wiring products parts.Cheched resistances as I went along to make sure they are good
joints.Carefully crimped with a standard crimp tool.Ever put a bit of heat shrink over the crimp part of the terminal to keep it all tidy.
