toyota vvtl-i megasquirt
t11 - 7/11/14 at 05:02 PM
Hi has anyone out there squirted a toyota 2zz vvtl-i engine, bearing in mind this a vvti engine with cam sensor's and more beside's a bit different to my 3sge, any thoughts welcome.........
Jenko - 7/11/14 at 06:25 PM
A few of us have had good results turning the VCT on and off on the puma engine (which also has a cam sensor)...Using ths method the cam sensor is not used, and the cam is turned back off again at higher revs.
