MSnSE 3 problems - problem 2
Steve Lovelock - 11/2/07 at 03:40 PM
The second problem is that when I follow this instruction:
All sensors should react to the corresponding pots on the stimulator. Before doing anything else, go to 'Tools/Calibrate AFR table' and select your sensor.
I come unstuck because I am not offered a Calibrate AFR table. The MAP sensor seems to be working though, any ideas?
