which AFR set-up
bigrich - 2/11/07 at 01:10 PM
i have been thinking about adding a wideband type AFR system so i can tweak the mapping of my car,
Which systems are you using etc
had a look at the dynojet set up but is there a better (read cheaper) alternative.
any thoughts
Rich
Is there a locost DIY option to keep in the spirit of the site.
matt_claydon - 2/11/07 at 01:18 PM
I think the Innovate LC-1 is the cheapest option. I've got one and am very happy with it. There are DIY systems I think but getting them working and calibrated is probably more hassle than it's worth.
garage19 - 2/11/07 at 01:33 PM
Here you go for a locost option.
http://www.14point7.com/JAW/JAW.htm
I use an LM-1. Very reliable and easy to use.
matt_claydon - 2/11/07 at 02:07 PM
Hadn't seen that one, looks quite well-designed.
bigrich - 2/11/07 at 02:18 PM
with the lc and lm systems do you run a dash gauge aswell or not
Rich
lc-1 £139.00
lc-1/gauge £179.00
lm-1 199.00
all on e-bay does it seem about the right price or have you bought direct from the US of A
matt_claydon - 2/11/07 at 02:53 PM
Don't really see the point in a dash gauge, certainly not if you've got fuel injection and can therefore record data logs. If the gauges were cheap then you might consider it as a matter of interest, but from what I've seen they are quite pricey and I don't really see what you would do with the information if you had it!
I bought from the US; think it ended up a bit over £100 including postage.
[Edited on 2/11/07 by matt_claydon]
