as the title - what spark plugs are people using for Pinto's with MS or MJ ?
aren't the standard ones man enough?
just open the gap a bit more
can anyone put a dimension to 'a bit wider' ?
Same as Rob for me. Cant remember the gap though (i probs posted details in maintenance section earlier this year).
I felt NGK 7's werent really needed on a predominantly road car. Take care with other makes of plugs - the numbers arent same as NGK.
thanks everyone
so basicaly everyone is using the Resistor type NGK APR6FS plugs then
but if anyone knows what gap they are using that would help
I heard 1mm.
