hello all
looking at the below fuel pump i cant tell which end is the suction, i am presuming its the larger of the 2 ie the 1/2" end with the green cap
many thanks
Look closely - there's usually an arrow on the casing showing the direction of flow.
Yep, that's right
thats the first thing i did, was had a look but no arrows
The low pressure side of the pump will have the larger diameter port, in this case the one on the left of the pic.
Yes the power terminal end is the outlet.,
