locating air intake
joscorstjens - 7/9/08 at 11:19 PM
Hi, I've built an injected Pinto-based Cat E1. Now I'm trying to get some cool air for the intake. Going to the front, next to the radiator seems logical but how do I avoid water coming in when driving in rainy weather?
tia
jos
blakep82 - 7/9/08 at 11:35 PM
ducting loiw down with nmaybe some kind of upside down U-bend arrangement?
so air enters low, has to travel upwards, and then back down to the in-take, that way any wetness show hopefully travel up the ducct, then run back down again?
BenB - 8/9/08 at 09:56 AM
I wouldn't bother worrying. A little bit of water going into the engine isn't going to be a problem. If anything it'll just prevent pinking
After all, what to people do with sausage type filters that stick out of the bonnet and are fully exposed to our glorious weather???
JAG - 8/9/08 at 02:04 PM
You do need to be careful.
I had water ingestion in my engine during last Summers floods. I think it was due to my low intake arrangements. I was very lucky and my engine survived with just a new headgasket.
My engine runs fuel injection and a single throttle body. The air filter is mounted about 6" off the ground, just in front of the engine. It's fine 99% of the time but can be an issue if you suddenly find yourself wading through 12" of water.
I would mount the filter as high off the ground as possible. I would have thought a duct from inside the nosecone/next to the radiator would be fine.
If the water is that deep you've got bigger things to worry about - like floating away
