What flasher units have you used as i need to get one and looking in the vehicle wiring products there are quite a few different units and im a little
confused
Tommy
After scouring the net a light brown buttoned unit seems to be most widely used.
First of all are you intending using LED indicators anywhere?
I used just a standard flasher, so I will look on the VWP website for you.
no LED's
ive got all std lights all round allready, i like the word standard but in the VWP cat there are a choice of 3, RFL3 (3 pins on the back) RFL5 (4 pins
on the back) and RFL9 (3 pins on the back but a different config to RFL3)
The RFL4 will be fine for you.
i would guess electro mechanical ones are full of electro magnets pulling metal conacts together etc, and electronic will be transistors etc, so no moving parts.
