Whats the name for the crimp connector in the pic please.
Used in the prem wiring looms ect.
cheers
Picture a bit unfocussed, but if it is circular, as it looks, then it is called a bullet connector.
Edited to say: Have a look in the Vehicle Wiring Products catalogue.
[Edited on 20/7/09 by Confused but excited.]
Could also be a scotchlock (I think )
May be a bullet connector - but may also be a unsheathed spade connector... picture not clear.
I know what it is But I'm affraid I don't know what its called, I do know that its none of the above though.
It doesn't plug into anything, it's to connect multiple wires together for feeds or earths.
Sorry I can't be any more help.
If that's the case, they are called a 'screw-it', as they screw onto the bared ends of the wires that are twisted together.
yep looked in vwp and there not in there.
Its for joining wires together ie a common live.
There is a metal crimp with a plastic mushroom on top
Warren
you are right they are joining multiple wires together earth,s or lives or even can be used to insulate a live end
we cheat in work and make them ourselves by using a small bit of brake pipe and insulating with heat shrink
hows that for locost
cheers les g
VWP page 21 Closed end connector / white ref.BCE 10= £1.00 + vat.
MIke.
Found them thanks for the help
Hows the build going Les ?
Hi warren
got a few hours in on the build this weekend
got me wishbones etc so gonna have a bit of a push now the overtime is tailing off again hows yours coming on ?
posted some picture on haynes forum in bodywork section tital trial fit have a look and tell what you think
cheers les g
