Racetechnology Dash 2, sensor adoption
Triggerhappy - 28/9/09 at 09:09 AM
Does aanybody have any simple schematic on how resistors and 5V reference goes together?
Also, how do i get RPM pick up lead to connect to busa engine, how?
My other sensors are oil pressure and water temp, and tankmeter...
imp paul - 28/9/09 at 09:20 AM
dont know if this helps you but here is the number +44(0) 1773537620 good luck paul
[Edited on 28/9/09 by imp paul]
turbodisplay - 28/9/09 at 12:15 PM
connect 5v to one end of resistor, other end to one sensor wire. Other sensor wire to ground (0V). Connect the dash input to the sensor wire connected to the resistor.
Darren
sucksqueezebangblow - 28/9/09 at 12:56 PM
One and two wire sensor linky
How do I connect my own sensor linky
Other useful linkys
lsdweb - 28/9/09 at 02:04 PM
As sucksqueezebangblow said - there's plenty of help on the site.
The forum is also very good with someuseful data on aftermarket sensor calibrations.
Wyn
SJL - 28/9/09 at 03:01 PM
Check the WSCC as there is a huge load of info an wiring the DASH 2 on there.
I have included the part numbers for the sensors and terminals etc in my post.
http://boardroom.wscc.co.uk/cgi-bin/ikonboard.cgi?act=ST;f=12;t=70576
