I've got either these:-
http://www.autoelectricsupplies.co.uk/product/438
or these
http://www.autoelectricsupplies.co.uk/product/437
The glass is broken so need to be replaced. I know both will fit but the looms are different.
Isn't the clue in the name? The second ones are sealed beam, i.e. it is one unit with the lens and reflector all in one unit; the other has a separate lens and reflector, and the bulb clips in the back.
Originally posted by MK9R
see now thats just made me step back from the way my head was working, i thought sealed unit meant bulb was sealed in there, but when i looked at pictures i couldn't see how that was possible!! I think i have the sealed units then Nice and cheap :p
Having owned numerous minis in the past I'd venture to suggest cheap and crap! If you replace them with halogen conversion lamps you will be amazed at the difference in the light output, and the connector for a sealed beam lamp and an H4 halogen is exactly the same.
Speak to Britpart they do a H4 conversion Kit for about £18
Can get them through PaddockSpares.co.uk
Not that much wrong with 7" sealed beams they are much better than tungsten bulb headlamps.
