As above, if so any pics?
What's going on?
Originally posted by coozer
What's going on?
Ruddy iPhone! Sorry!!
Do you mean HID projectors?
http://locostbuilders.co.uk/viewthread.php?tid=138151
I would assume he means prismatic projectors?
Like these
[img]
Tw proj on 7 on
[/img]
[img]
Tw proj on 7 off
[/img]
[img]
Tw proj on 7 close up
[/img]
£230 a set of 4 less 10% to Locosters, not sure where the sidelights are from, but not mine - I use a combined indicater & sidelight.
thats the badger russ. I'm having a think on what to fit as i'm now skint!
oooooooh russbot you are a BAD BAD man!
I'm trying to be good with my money and pictures like that of those lights are OUT OF ORDER!
Can only recommend the lights from Russ, they're fitted to the R4
I know what you mean, however in his defence they are the same ones fitted to the caterham!
Seems showing a car in IVA mode isn't the best. the indicators have to be higher than the wing or something and the headlights above! Post IVA
the mount is designed to be chopped down by 2" or so. They are 7" lights though
Not sure I could use the projectors above as the mount isn't the correct shape. Might have to look into it!
Anything can be made to fit!
