As the title says - that way, when you turn, the lights will light up where you are going! -
any reason why it can't be done?
Well it could be done but, as the wheels move up and down so would the lights. Surely that would leave the light beams all over the place? Also, is it not advisable to minimise unsprung weight?
The vibration wouldn't make your bulbs last for long either. I think there's some IVA rule about which beams can turn with the wheels and which can't too.
How about mounting them in the usual place on a pivot, then a connecting rod between it and the wing stay,
Then you wont get the up down movement just the left and right
Citreon had that system years ago.
If the IVA had a silly rule like that it would make most unfaired motorcyles illegal.
When we are blatting in the lanes local to me we could do with such a system.
i was thinking of a bearing and a morse cable to bring the transiton movement to the contraption.
self leveling to comply with the hid requirements would be cool as well.
[Edited on 2-8-10 by mangogrooveworkshop]
It's hard enough to stop wing stays snapping with just 500g of fibreblass on them... couple of kg of light and they've got no hope! So you'll need to massively beef up the wing stay.
MMM.... interesting replies so far.....many drawbacks being pointed out, but.....keep 'em coming, guys (and gals!).
Originally posted by daviep
surely the wheels don't actually move up and down unless you have really big bouncy tires, it's the body which moves on the suspension but looks like the wheels are moving as we are moving with the body?
I would have thought it was the other way round, surely the wheels don't actually move up and down unless you have really big bouncy tires, it's the body which moves on the suspension but looks like the wheels are moving as we are moving with the body?
Davie
Thanks for the interesting discussion, guys - but as I'm a coward, I'm still going to mount them in the standard location even though I like
to be different (don't we all?)
I think the examiner will find enough flaws in my build (let alone the car's!!) without me manufacturing some extra ones in!!!
Cheers, Steve.
Oops! Page 166 of the IVA (may'09 update)......
3. All lamps and reflectors fitted to the vehicle must be fixed and not move by swivelling, deflecting or otherwise while the vehicle is in motion,
except for:
any lamp or reflector which by design can be deflected to the side with the movement of the front wheel or wheels of the vehicle when turned for the
purpose of steering the vehicle
a headlamp for adjustment or dipping of the beam.
Guess this means the government have cast their vote on this one!!!
