Do side lights have to be powered from a permanent live and dipped / main beam powered from the ignition?
The switch I bought from CBS only has 3 pins so all the lights have to be powered from the same source. I'm a bit annoyed because the hazard
switch I bought from them also has 1 fewer pin than is actually needed.
Yes run power through fuse box permanent live to switch
Could you wire the hazards and the side lights from a permanent live and run the "out" side of the mains through a relay that only works when the ignition is on?
The CBS switch is the simplest way of wiring the lights. Personally I would have the headlights powered from a switched live so that you can't make the easy mistake of leaving the headlights on when parked - one advantage of using the Sierra switchgear.
use the switch to power relays.
the switch and side's relay is perm live and the others of a switched live.
job done
