can you recommend me the best option for fog and reverse lights?????
cheers steve
1 red and 1 white would best I reckon
Rich
(May need a little more info on what your taste is like, flush mounted,housed, led etc)
ha ha nice one..i bought mine from bolt on bits off ebay.
Just remember that the Fog light has to be a specific fog light (with the correct E mark) as the lens/reflector on them gives a narrower, intenser
beam than a brake light for instance. Several have failed recently for incorrect lamps (sold as fog lights in a set I believe). Also remember it has
to be mounted so the lens surface is vertical, not just close or it'll fail.
Personally I like these or
these. I think they look neater when mounted from behind through the rear panel than the
larger more common types that surface mount on a base.
