Lighting Questions / Clarification
MikeFellows - 3/10/11 at 09:50 AM
Im about to fit all my rear lights and want to confirm a few things before I start
firstly can anyone confirm this picture is still valid
secondly I have 4 round lights that are all the same size
2 lights do stop, tail and indicator
1 light does fog
1 light does reverse
I planned on putting 2 on each cycle wing and having no lights on the rear panel, but i need 10cm gap between to 2, will this be measured from the edge of the light or the edge of the light mount where it meets the cycle wing?
finally to confirm that all lights need to sit perfectly straight (as in at right angles to the ground)?
adithorp - 3/10/11 at 10:40 AM
Yes the info there is still valid.
The distance apart is between the light emitting surfaces (so the lens not the base).
The only light that must be perpendicular to the ground is the Fog light.
MikeFellows - 3/10/11 at 10:51 AM
thanks for that
i guess all my lights are going to have to be perpendicular as they are all the same. and it will look weird with the fog sat straight
loggyboy - 3/10/11 at 01:09 PM
There are a couple of minor changes/tweaks since IVA was introduced:
Min 600 seperation of reflectors is no longer required.
Reverse is mandatory and as such has 250mm min height and a 1200 max.
