Hello,
2 quick questions about accessories on a 2.0 EFI SOHC engine
1 . is it a problem if i fix the coil to the plate under the inlet manifold instead of fixing it to the chassis ?
2 . is it a problem if i mount the air flow meter upside down ? ( the air flow meter will stay horizontal)
Waiting for your replies .
Gerardo
Number 1 i would say its a bad idea because of heat coming of the engine
number 2 sorry i don't know
Jacko
i have my coil pack on my pinto mounted to a modded dissy and its fine basicaly cut the top off the dizzy leaving the shaft and gear in place and
mount a plate on it and its fine
i dont think it would make any difference which way the airflow meter is mounter as its just a heater element normaly
My coil is mounted on the inlet plenum chamber, I am on my third one in 7 years
The airflow meter works on the spring loaded trap door principle, so I suspect if exactly inverted it would still work although I haven't tried
this. I am sure it wouldn't work if mounted at 90° to its intended plane.
like this
Thanks for advices,
Gerardo
Hello,
after seing the way Mark Allanson did his own airbox ( he send me a pdf file files with many details), i tried myself.
So here it is :
and
I still need to weld the depressure pipe for the fuel regulator, but i did not have the required pipe.
I also have to modifiy the way the gaz cable will actuate ( it will not be placed as on the picture , but it will come in the oposite way,from theback
of the car if you understand what i mean), but this part is broken:
Do you know it's name ?
Does somebody have one lying around that i could buy ?
Gerardo
One name would be a throttle quadrant. You will only find another on a another Tb I would say.
